slop...Roundman, JD, OB..anyone help???
Ok heres the question. when Im driving my car in 1st going 10mph, when push my clutch in and out I feel a cluck kninda feeling like my Drive shaft was loose, I have my friend check it out and he said it probally wasnt the D/S, he said its called "slop" where theres a little slack in the D/S U- joints. So when I was board I thought id check this problem out. I jacked up the rear, so both tires are off the ground, I have the e-brake off, so I can spin the tires freely, well when I start to move the tires, I notice that the tires will move about 1/4 inch before the drive shaft starts to move. So basicly my tires will turn 1/4" or so before my D/S will start to move. there is a little free play. Is there supose to be free play like that? Is it called "slop". I can feel this when I shift real quick and when I let off the gas and get back on, its like there is a small jerk when i get back on the gas. Does anyone have similar prob? how can I fix it?
RE: slop...Roundman, JD, OB..anyone help???
There's going to be a noticeable amount of distence that the tires will rotate before the ring gear moves the pinion gear. This is called backlash. Blacklash of the ring gear should be only about .008-.011". The larger diameter of the tire will amplify the backlash of the rear end and you will see what you're getting. Now if you can actually hear a clunk really bad when starting out or decellerating, and you're "slop" is something fierce, then I'd check your rear end, after you checked your u-joints of course.
It didnt start doing for about a 4weeks after i had them installed, it started doing it after I went to the track about 2 weeks ago. Is this problem because the gears were installed correctly. Or is it my U-joints are worn out from the drag strip? Will this be an expensive problem to fix? Does anyone else have this same problem? is this something that I cant just tighten the D/s bolt and tighten up the U-joints bolts or something?
Try jacking up the rear again and have someone start the car and spin the tires a little
See if it makes the noise there. If it does listen to where it's comming from.
It may not make the noise because there's no load on the tires, but atleast you can give it a shot.
But yeah, just replace the U-Joints anyways.
Quick easy and inexpensive and they probably havn't been changed the life of the car.
