Hydraulic vs Solid roller
ORIGINAL: Aixtreme89
I just got my motor built about 6 months ago. I havent heard of new technology in hydraulic lifters. At about 6700rpm. the hydraulic lifters pump up with oil and cause the valves to remain open. So basiclly thats the highest you can rev your engine. I know with solid lifters you can rev your engine atleast 8000rpm. BUt you have to make sure your rotating assembly can handle it.
Show me an article or anything about these new hydrualic lifters.
Thats interesting. http://www.andersonfordmotorsport.co...t/50-cams.html
Wouldnt you think they would rev them up a little higher on the dyno. The only cam that went past 6800rpm is the N-111.
I have to agree wit uedlose. You can get a roller lifter in either hydraulic or solid form and you can get a flat tappet lifter in solid or hydraulic form. The roller lifters in a 5.0 are hydraulic. The difference between flat tappet and roller is simple. The difference is self explanatory. Roller lifters have a "wheel" or "roller" at the bottom where it rides on the cam and "flat tappet" lifters are flat on the bottom and ride directly on the cam lobe. Here is a picture of roller lifters (notice the wheels at the bottom of each)
These are flat tappet lifters ( you are looking at the bottom of them, notice they are flat, no rollers)
The difference between solid and hydraulic is also self explanitory. "Solid" lifters are exactly that, solid, they are solid and have no give to them so they have to be adjusted precisely and require readjustment every so often. Hydraulic lifters have a spring loaded plunger in them where the pushrod rests on the lifter and oil pressure builds up behind the plunger so that the valve is fairly solid so long as the oil pressure is good.
Here is a cutaway diagram of a hydraulic lifter
Hope I helped a little.
its not a article it is racers talking about cams. there is also a formula to figure this all out I cant remember where it is but find it and do the math a renegade car runs 8.80 at 151mph with a 28 in tall tire 3.73 gears with a 306 and they MUST run stock ford roller lifters.do a search on valve float on hard core or on corral net.if you want to know more I am not the one blind to this. I showed you anderson and why dont you E-mail ED talk with him he is the camshaft master not me.I just know what I see hell I was running the wifes car to 7000 rpm with a F-cam and stock lifter with TFS TW heads and a supercharger for a while till I put a smaller pulley on the S/C and was afraid I would over spin it.
i love my solid rollers ...rev high...my low lash cam motion cam has .010 valve lash hot ..no noise! the cam i had in my video ,,is in my truck now ,,its runs a lot stronger than my hyd roller....just got to put my 11inch converter back in ,,it was defective ,,got new one ,,than i will go run it ..
here some pics of my solid roller set up ...
[IMG]local://upfiles/10419/91794824824048E6AF52B649A2AA6B6E.jpg[/IMG]
here some pics of my solid roller set up ...[IMG]local://upfiles/10419/91794824824048E6AF52B649A2AA6B6E.jpg[/IMG]
Yeah I know that. We where discussing the the rev capability of hydrualic roller lifters.
