supercharger
RE: supercharger
ORIGINAL: Olive1465
hey with procharger do you have to make a hole in the oil pan and what is the mantinace on it
Yes, I have an otherwise stock engine...well for the most part. The camshaft is aftermarket (Steeda #19) but the block and internals are stock. Running 10 PSI of boost as well as a two-stage nitrous setup. 50hp dry stage followed by a 100hp wet stage. At first I was using methanol injection as a chemical intercooler. I have since added an air-to-air intercooler to the mix.
RE: supercharger
I've got just over 84,000 on it. But 103,000 isn't bad. You shouldn't have any problems. Pro50SC has some high miles on his procharged fox and has no problems at all.
How long it takes to install depends on how much time you have to spend on it each day, what tools you have avaialble, and how well you know engines. It should'nt take you more than a weekend to get it installed and tuned properly.
RE: supercharger
If you have the right tools, then plan on spending a few days on it and take your time. They come with very detailed instructions so that will help a lot. And just take pics of everything along the way. Also lable your lines that you remove, etc. That will help when it's time to put it back together again.
RE: supercharger
what do you guys think about puttin a vortech v-2 on a 110k mile motor..i mean it runs strong and it have no problems with it. all thats done is a gt40 intake n exhaust..will this work out ok..i checked that site superchargers4less..and there price is like 2735.00...best ive found so far...anyway..just seein what ya think about the motor integrity
