oil pressure fluctuating???
Old Oct 3, 2007 | 07:43 PM
  #21
ptown87's Avatar
ptown87
Default RE: oil pressure fluctuating???
I had the same problem. First of all you can't always rely on the stock gauges. I would replace the stock gauge with an autometer. If your levels are still low you probably have one of the follow wrong: bad crank and bearings, bad oil pump, bad pick-up screen. The crank and bearing will go bad on these cars especially if they are high mileage and beat on. If you don't drive your car in cold weather you should try to just put in a thicker oil. I ran straight 40 weight in mine for a little while defore i had the crank and bearings replaced. It will help.
Old Oct 3, 2007 | 09:36 PM
  #22
dillon1340's Avatar
dillon1340
ORIGINAL: mattdel
ORIGINAL: dillon1340
ORIGINAL: aode06
underdrive pullies can cause this on a fox body,
what happens to my car, is that the pullies dramatically slows revolutions of the ACCESSORIES OF THE MOTOR and the alternator, electrical system, waterpump, cooling fan may not function properly if left like this for a while.
The available voltage are shared upon the fuel pump, radio a/c etc .
AC may blow hot, car may get hot, and the oil pressure guage will not function properly etc, and Ive measured 11.10 volts, this is with a 3g alternator , oversized pulley and Optima.
As soon as you tap on the gas, everything is back to normal. So, id advise to turn the idle up a lil or swap the pullies back to stock.
You take off a valve cover and will discover oil pressure is just fine, things dont like to function right at lower voltages and revolutions on a fox body sometimes.
isn't that why they put a voltage regulator on the instrument panel? so the gauges aren't affected by voltage changes?
right. but a voltage regulator can't keep voltage above what isn't available.
ok that makes sense. my temp gauge and oil pressure gauge both read high when i have my headlights on. i was goin to replace the voltage regulator in the instrument panel. this won't fix that problem then will it? it's a new alternator that keeps things around 13.5 volts, 13 with the headlights on.
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
wraith777
Sep 28, 2015 10:49 AM
SteelerNation82
Sep 16, 2015 07:11 AM
