Lights going out Help!!!
I just bought a 92 GT. It is all stock, beats the crap out of my 87. Anyway the other night when i was driving the lights went out. By lights I mean the headlights and fog lights. The dash stayed on and the marker lights did too. I use to have a ford truck with the bright light switch on the floor and the bright lights went out like this. They go out but come back on and there seems to be no apparent rhyme or reason when they do it. Anyway on that old truck it was just the bright light switch so I am thinking it could be just the light switch, but wanted to see if anyone had any other suggestions.
RE: Lights going out Help!!!
MFS... multifunction switch, its on the column, it controls hi/low beams, wipers, and turnsignals... thats the problem
for future referance, dont use your headlights and fogs at the same time, it over heats this connector/switch, and ****s **** up
I have the same problem with my "90 gt. I changed the headlight switch and later found out it is the multifunction switch thats bad. If I shake it and go back and forth from brights to regular lights, the headlights come back on most of the time.
heres a fix to your problem.
this alone will work as long as your headlight & multifunction switch are still in good working condition
http://www.corral.net/tech/maintenance/foglights.html
my 88GT is doing the same thing right now, so i talked to a ase ford tech and he said the most common problem was the headlight switch getting hot, to replace it and check the other connector to see if it melted because that may need to be replaced too. so im going out to change the switch right now ill post later tonight for the update.
