TFS stage 1 cam
TFS stage 1 cam
HI .. i just want to know if it will change something if I install the TFS stage 1 cam in my 5.0 1989
now i got gt-40 intake, 70mm TB, 75mm MAF, pulley, complete accel ignition, k&n, full exhaust, 24 lbs injector, that sit ...
how much horsepower can i get??
thanks
thanks
RE: TFS stage 1 cam
You could run the stage 1 cam with the stock springs. Ive seen it done a few times. Once you start getting above .512 lift it is good to get different ones, but it would not hurt to get different ones but not totally neccesary
RE: TFS stage 1 cam
ORIGINAL: 15austin
RE: TFS stage 1 cam
Ok my bad.. Just talking from my personal experience and 5-6 other in my area ran the f-cam with stock springs for 5-6 years and ran great the whole time. Sometimes real life and what some book says differ. (for that cam springs are not REQUIRED just recommended in real life)
RE: TFS stage 1 cam
Yep....you're right..... change the cam for one with faster/longer duration and higher valve opening lobes than the stock cam, and keep the stock springs.....that is not important. Didn't know they measured pressure, installed height, pressure rate and coil bind height in those F-cam setups...... [sm=imsorry.gif]
Could you imagine how much better those f-cammies would have run with the proper valve train setup?........ but then again, no experience here.... ...... [sm=signs003.gif]
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
