What Cam ???
Old Sep 23, 2003 | 12:01 AM
StangGt92's Avatar
StangGt92
Default What Cam ???
I have a 1992 Mustang GT 5.0 and i am looking to put a camshaft in with a rough idle.... but i dont want to but new heads or have the need to buy new rods or rockers..... is there a camshaft out there w/ a rough idle that can slip into a 5.0L without major modifications??
Old Sep 23, 2003 | 12:13 AM
T5superduty's Avatar
T5superduty
Mabye Try the B-303 camshaft from ford racing. it has 480" lift 284 degrees ofduration, and has a pretty mean idle to it. Check out some cam reviews- http://reviews.stangnet.com/review.cgi?ID=209 </P>
If you want more high end power and lopy idle from your 5.0 this is a pretty good choice</P><edited><editID>T5superduty</editID><editDate>37886.9268402778</editDate></edited>
Old Sep 23, 2003 | 03:31 PM
94kbscobra's Avatar
94kbscobra
e303 or b303 from ford racing. do not install a huge cam or you will be sorry. horrible performance and driveability, the car will sound like a muffled pro stocker but run like a honda on 2 cylinders.
Old Sep 23, 2003 | 03:59 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
go with the b, its easy on the valvetrain, good performance and sound
Old Sep 23, 2003 | 05:26 PM
94kbscobra's Avatar
94kbscobra
well if your looking for a lopey idle my friend has an e303 in his 5.0 and it sounds awsome. the e303 gives a little more lift and less duration than the b303 but the e303 is also emissions legal on a 5 speed stick car. carb e.o. #D-225-16 which is your best bet if emissions are strict were ur from.</P>
Old Sep 23, 2003 | 06:53 PM
T5superduty
That is true I forget all the time about emissions because I dont have to smog my V8s <IMG src=smileys/smiley2.gif border="0"> E-303 would be a good choice but the B-303 makes more horspower and way more lopy. And if you get 1.7 rockers it gives it the same lift as the E-303 and with more duration. <edited><editID>T5superduty</editID><editDate>37887.7059837963</editDate></edited>
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
