making dumps?
#21
RE: making dumps?
i ran just mufflers for a while, and sounded loud, but raspy i guess, kinda ratty, i put turndowns on it and reflected them more out than just straight down so it didn't rap off the ground, sounds awsome, loud as ****, but not too bad, smell really isn't ever a problem unless u sitt in traffic with ur mustang wich i'm sure just bout nobody does, but other than that u'll be pleazed. U won't lose any horsepower, there is no way that taking away more restriction will cause u to lose it with the little bit u take away from your exhaust, if anything i have noticed a improvement on how my car ran, i wouldn't say faster at all, but just seemed to respond well.
#22
RE: making dumps?
ORIGINAL: 90_Mustang_GT
I dont have troubles with the smells. Sitting still for a lil while you may get a wiff but you should be fine.
#26
RE: making dumps?
id let about 4 to 5 inches at least at first, it's easier to cut more off later then to be screwed, cut them, and put the dumps on see if it looks good to u, if not just cut away a little more. you'll need enough room for the clamp for the dumps if your not gona weld it on
#29
RE: making dumps?
hmm on my flowmasters the tail pipes are being held on by clamps, if i loosen the clamps will the tail pipes just slide out? its a 88GT i was lookin at it today and where the mufflers are makes it kinda hard to cut anything cause as soon as the tail pipe leaves hte muffler it bends upwards over the rearend... mmmm and the hangers how do i get those off? i plan on holding onto the tail pipes just incase but i won' have this car long enoigh for next inspection so i don't care really
