Compression numbers
RE: Compression numbers
what year mustang are you working on?? are you chasing low compression probs, valvetrain noises or what was the original complaint with the idle?????? and what cam tfs stage 1????
i hate to ask a dumb question BUT.......
1) the motor was warmed up b4 the test right ?
2) did you dump a little oil ineach cylinderto see if the numbers picked up ?
2 - I did not use any oil as it is a brand new build and I would hope to god the rings and seals are good.
what is your ring gap?
ORIGINAL: Joel5.0
Redo the valve train....those valves are not closing, I've seen higher comp numbers in 200k miles lo-comp engines.....and make sure you have the correct pushrod length.....not because you were told to use them, but b/c you measured and set its geometry...... just a thought.
Don't worry about it, those are "growing pains" when you start getting involved with this stuff..... even if you would have had decided to go with AFR's, you need to do the valve train geometry/PR length setting exercise.... there's no way around it, that is, if you want to do it the right way.
Buy/borrow the adjustable PR's and make sure you check/set that geometry ....... is it really that important you ask?..... check this article .... not having it set correctly = you loose some of the cam induced lift..... a .510" lift could be .490" when set incorrectly.
once your sure the valvetrain is set correctly like Joel5.0 says and you have no vaccum leaks then check your tune up parts like cap,rotor and wires....it doesn't matter if you say they are new...cause many times I've put new tune up parts on that right out of the box were crap.....2 years ago after a similar project of mine on my 66 I had a bad miss on my 66 build and Iwent bought a new cap...fixed it for 10 min and prob started again.....returned cap bought another and same result.......finally I said screw this cheap *** cap from napa's econoline and grabbed a used one that was still in fairly good shape with brass terminals instead of carbon ones and wham problem is gone...still got the used cap on to this date.......not saying that is your problem just an example double check all valvetrain set up and timing and work your way out from there
Cool, thanks for the help. I ended up just sleeping on it so I did not break anything. A buddy of mine who has set valve trains is comming down today. He has a push rod measuring tool. I have rebuilt a couple engine before, but those engines always had torque specs for the rocker arms, so that made it easy.
As for the cheap parts, I am going to look into that as well. As I went cheap on the rotor button, cap, and wires. They are Autozone 1 years.
