Compression numbers
Old Oct 11, 2007 | 04:38 PM
wolverine8490's Avatar
wolverine8490
Default Compression numbers
In chasing my idle, performance issues, I decided to run a compression test on my engine. It is a 306 with TFS heads and intake. It has only about 100miles since the rebuild and the numbers seem really low:
1 - 119
2 - 119
3 - 119
4 - 119
5 - 119
6 - 119
7 - 119
8 - 119
They are all consistant, but I cant figure out why they are so low for a brand new engine. The only thing I can think of is if I tighted down the rockers to tight. Trick flow said to turn the 1/2 - 3/4 turns past zero lash. I was getting a lot of ticking when I used that, so I turned them 1 full turn, and the ticking went away. Would that cause issues?
Old Oct 11, 2007 | 04:56 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: Compression numbers
there is an issue there
its not head gaskets though...
Old Oct 11, 2007 | 05:12 PM
wolverine8490
I am debating whether or not to walk downstairs, pull the valve covers, and lossen all of the rockers about 1/2 of a turn. I really hate adjusting valves. Maybe all of the ticking I heard at first was just beacuse the lifters had not pumped up yet.
Old Oct 11, 2007 | 05:16 PM
ahittz24's Avatar
ahittz24
you are supposed to tighten the rocker nuts to 15lbs/ft of torque with the valve seated on the head. you have to spin the engine over a few times to get the valves set right.
Old Oct 11, 2007 | 05:26 PM
wolverine8490
I used the following directions to adjust mine. Except I turned them 1 full turn:
" If you are using a hydraulic cam and no specs are available, turn the rocker arm adjusting nut 1/2 to 3/4 of a turn after zero lash. For mechanical cams, you must get the correct lash specification from the cam maker."
I just talked to a buddy of mine, and he is thinking that the timing chain is off 1 tooth. He said that is about the only way that the numbers would be all that low and equal. If he is right, I am going to shoot myself. [:@]
Old Oct 11, 2007 | 06:29 PM
vtecwho's Avatar
vtecwho
are you sure your gauge is right?
Old Oct 11, 2007 | 06:44 PM
Joel5.0's Avatar
Joel5.0
Redo the valve train....those valves are not closing, I've seen higher comp numbers in 200k miles lo-comp engines.....and make sure you have the correct pushrod length.....not because you were told to use them, but b/c you measured and set its geometry...... just a thought.
Old Oct 11, 2007 | 06:51 PM
wolverine8490
Yeah, I have used the guage before not to long ago on a car I used to have and it worked perfect.
I pulled the valve cover off and loosened the rockers on Cyl #1. I first loosened it 1/4 of a turn, and it rasied the compression to about 121. Then I loosened it another 1/4 of a turn, and it lowered the compression to 93.
I think I am going to take off the timing chain cover and make sure it is set ok. The pushrods I am using came with the TFS kit, so I would hope they are correct.
Old Oct 11, 2007 | 07:01 PM
Joel5.0's Avatar
Joel5.0
ORIGINAL: wolverine8490
1.
2. If you had the timing chain 1-tooth off.......you could also have a few bent valves like.......
Old Oct 11, 2007 | 08:01 PM
wolverine8490
Well,
from the looks of it the timing chain was good. The picture attached sucks, but you can kind of see. It did not make any noises like valves were hitting. I made sure to crank the motor before hooing up the ignition to make sure no valves would hit.
I hate cars. [:@]
