I think that my module is going bad. My car starts but cuts off after idleing for a second. If I hold the gas and keep the revs up it will cut off and on , but keep running because the rpms are up until it picks it back up again. Has any one had this problem before?
so, no matter what itll cut off after a few seconds of running? sounds like the ignition module, on the side of your distributor, but id check to be sure before you replace it
they have a tester at like advance i think, ust bring it to them, and they plug it up and it checks it, make sure they run it a couple times, and if its bad your already there to buy another one lol
well the module is ok and the coil is ok as well. I am out of ideas. I know that its not a fuel problem. its getting fuel. does any one have any other ideas?
