steeda 19 cam
RE: steeda 19 cam
*edit* *the cam i have surges a little for about 3-4minutes after startup, then once its driven, no more problems again*
94yellow, yes the steeda 19 works good in our cars.
i have a comp cam Xtreme Energy (XE270HR-14) .512 lift and rpm range is 1800-5800
i have an aode also with a 3500 stall, they can be great and bad also...
upsides: easy to drive & consistant
downsides: cost on a good rebuild w/ new high performance stuff will be pretty pricey, labor is the big killer. i had mine built and 400 miles later its toast again, either mine or the tranny guys fault, dont know yet, may not ever know.
i dont think i would trade my aode, maby for a 4r70w, but i can take my aode, put the wide ratio gear set in, and have pretty much the same tranny as 4r70w. a stall makes the car fun to drive, foot braking at 3k, well its, addictive LOL
RE: steeda 19 cam
ORIGINAL: 91hatchgt
Hey Onyx, just wondering why you are going from the 75mm MAF to the 90mm LMAF? Change injector size or what?
ORIGINAL: OnyxCobra
I have no complaints with my setup running through a Cobra intake. It's not tuned yet but my tuner says I should see 12s without much of a problem.
RE: steeda 19 cam
ORIGINAL: 91hatchgt
Really? A 75mm MAF maxed out with AFR 165 heads? Wierd..
RE: steeda 19 cam
ORIGINAL: 91hatchgt
Can't you get the Pro-M recalibrated for cheap?
09-24-2015 09:18 PM
