Headers glowing
Old Oct 13, 2007 | 04:33 PM
94RedDevil's Avatar
94RedDevil
Default Headers glowing
Every time that i turn the car on, the headers start to turn red at the bends. It starts first on the drivers side on the 3rd cylinder. I know to retard the timing, i tried but there is a point where you retard it so much that you can not turn the car on. Any suggestions?
Old Oct 13, 2007 | 04:43 PM
Boss_Hotrod's Avatar
Boss_Hotrod
Default RE: Headers glowing
You're running too lean. Check your fuel pressure and intake hoses (and intake) for air leaks. Retarding the timing will help to a point.
cheetha94607's Avatar
cheetha94607
do you have stock ingnition system?
did you change to cooler plugs?
might need to change injectors.
Old Oct 13, 2007 | 04:54 PM
94RedDevil's Avatar
94RedDevil
The ignition is stock up to the distributor. I bumped the fp up to 60, it was running fine b4 with the fp at 60 but now its glowing. I dont know if i should go anymore thanthat, what do you think? Could i run injector cleaner through it. I upgraded to 24 lb injectors about 600 miles ago and they were running fine. I did not have my mafhooked up properly until just now. Possibly the problem?
Old Oct 13, 2007 | 04:55 PM
94RedDevil's Avatar
94RedDevil
wth is a cooler plug?
Old Oct 13, 2007 | 05:32 PM
94RedDevil's Avatar
94RedDevil
nvm, i did the google, i thought that cooler plug was one word not like cooler spark plug, sorry. Why would i do that? should i ?
Old Oct 13, 2007 | 05:45 PM
Boss_Hotrod
I dont know if the maf being hooked up wrong would hurt it or not. Run it again witht he maf hooked up preperly and try it again. Maybe since you switched to 24#ers the computer only thought they were the stock 19#ers and that was why you were lean.
Old Oct 13, 2007 | 05:49 PM
cheetha94607
some manufacturer recommand changing to different plugs .
(Too hot of a plug may, however, indirectly lead to a runaway pre-ignition condition that can increase engine temperature.) Rather, the main effect of a "hot" or "cold" plug is to affect the temperature of the tip of the spark plug.
Old Oct 13, 2007 | 06:14 PM
KELRMN2's Avatar
KELRMN2
fuel pressure sounds too high to me... 60psi? Probably running way fat.
Old Oct 13, 2007 | 06:20 PM
Texas5.0's Avatar
Texas5.0
Whats your temp gauge saying?
