Vibration--HELP!!!!
Vibration--HELP!!!!
I have posted this before and thought maybe found the problem. Nope. I have a 90 fox 5.0 5spd car. 3.73 rear gears. It has a vibration at about 78-80 mph. Have put a vibration sensor from a Ford dealer where I work on it, and found that the most g's were coming from the axle housing. So, we re-built the rear end this past weekend. Different ring and pinion, new side gears, pinion bearings. The side gear splines were loose on the axles shaft splines. The new ones took about 50% of the play out. I know it will need new axles befor long. Could it have a bent axle at the splined end? Have check the axles on the flange with a dial indicator, no problem. Any ideas where or what this vibration could be?
We have swapped the wheels, driveshaft, ran it without the brake drums on. Still the same results. Please help with ANY info. Thanks alot guys.
RE: Vibration--HELP!!!!
It's vibrating only at moderately high speeds? Harmonic Dampner perhaps? My car vibrates really badly at low rpms and the shifter as well. When I go to 50+ it smoothes out. Some told me, if my vibrations happens at high RPM then it would be my Harmonic Dampner/Balancer. Since mine has the shakes at low rpms it's probably my fan and clutch causing it. I'm replacing those next week.
ORIGINAL: bbbngowc
It's vibrating only at moderately high speeds? Harmonic Dampner perhaps? My car vibrates really badly at low rpms and the shifter as well. When I go to 50+ it smoothes out. Someone told me, if my vibrations happens at high RPM then it would be my Harmonic Dampner/Balancer. Since mine has the shakes at low rpms it's probably my fan and clutch causing it. I'm replacing those next week.
