electric fan push or pull
RE: electric fan push or pull
Puller in my opinion is best, I mean, when your drivin the air flows thru the radiator, so your pulling the air with the fan as your driving. You can get the Black Magic fans, there reversible depending on how you wire it, to pull or push.
i will end up with a pull then.....just wondering if it made a difference. this one guy i know uses for all his track cars a push fan on the outside of the rad.....weird
If it's on the outside pushing air thru radiator, it's the same as being on the inside pulling. The air is going the same way. On a standard motor driven fan (fan clutch) it pulls.
mrappe
09-26-2015 10:16 AM
09-25-2015 09:06 AM
