Installing 4 barrel TB
Got my Accufab 4 barrel throttle body in.
Can anyone give me some pointers on what it takes to install a carb style
throttle cable off an '85 Mustang. Any brackets I need? ect?
Check it out ......... Kick ***
RE: Installing 4 barrel TB
so does that mount where the throttle body originaly was or do you put it ontop of the lower intake like a carb setup would be. probably hvaing to get a diffierent lower then you already have.pretty interesting.
ORIGINAL: adumb
Still need any info on this from anyone thats done a carb swap.
It comes with its own GM style TPS and IAC, they just aren't mounted to it yet.
Had to go spend $100 on the little freak'n plugs for them from local Chevy dealer[:@]
Yep those are LS1 coil packs[8D]
You will need one bracket that goes on your intake to hold the *casing* i guess you would call it for you can move the throttle. you can make the bracket if need be or just get an adjustible one from Lokar
