5 speed swap ?
5 speed swap ?
do i need the computer from the 5speed car to put into my aode car when i swap the trannys...i ask because i thought that i wouldnt need it anymore since it wont need to tell anything to shift..but someone told me that i might cuz they heard that with the auto computer that it would bog down a little cuz it would act like it wanted to shift n couldnt...itsa 94 5.0 btw...so if anyone knows thanks
RE: 5 speed swap ?
i have gotten mixed opinions on this same thing.. there is a article on allfordmustangs.com i think that says you can just have a mechanic fix the problem with the computer. it is just a setting that is at like .3 and you can have a mechanic put it to 0 which is no delay. it isn' about replacing anything just reprogramming it to work with the five speed.
i did ask a guy at a speed shop and he said it isn't necessary. i guess it depends on who you ask.
RE: 5 speed swap ?
this is the article. it talks about the computers about 3/4 of the way down on the left. it is highlighted in gray. it may just be easier to plug and play with a 5 speed computer. how expensive do you think they are?
http://www.allfordmustangs.com/Detailed/25.shtml
RE: 5 speed swap ?
hey i just did a quick search and heres what i found the price and everything its 369.99 the url is http://www.need-4-speed.com/eectuner.htm
RE: 5 speed swap ?
There are a few ways to do this, with their drawbacks......BTSTDT.
1. Leave the auto ECM on, place a jumper wire to create a permanent in-neutral signal from the auto MLP sensor.
[ul][*]Starter will be activated in-gear w/out pressing clutch pedal (safety)[*]Transmission "load signal" will never be generated (performance deteriorates)[*]Transmission solenoids codes will be logged (forcing the ECM into a "limp mode" strategy)[/ul]2. Replace auto ECM for a manual ECM
[ul][*]Transmission "load signal" will not be generated, unless you wire a neutral switch to the clutch pedal and to the correspondent MLPS pin at the ECM (pin #30).[/ul]3. Have a chip programmed with the correct scalar value for the trans_strategy_switch.
4. Install a Tweecer or aftermarket EEC Tuner and modify the logic for that upgrade.......and others planned down the road......
From the alternatives above, #4 is the most effective even though it requires an investment and learning how to use it. And the reason is that it will allow you to modify the ECM for a transmission upgrade now + ANY other modifications (including a good performance cam) you may add in the future w/out been limited by the SN95 ECM peculiarities.... just a thought.
