GT-40P headers question
How much modification is needed to the headers for the GT-40P heads. Is it worth it to attemp. do they make shorter spark pluggs too. i thought that i read something about that. I know that this question is asked alot but i couldent find the answer in the forums. thanks
I ran bbk shortys with gtp's ,The pass side header worked fine and had no issues w/ wires/pulgs.The drivers side,i had to use a 90deg sparkplug boot on one of the plugs.Also you will have to cut down a socket "like the ls1's use" to take out the plugs on the driverside.The frpp headers are made to fit p heads.
do you think that i would have a problem with these http://store.summitracing.com/partde...p;autoview=sku? there not the best headers but they work. any ideas? Do the 40P's flow a lot better than the 40's or not really a big differernce. i know that the P's flo better but is it a noticible difference?
if BBK long tubes work summit will work, they are same design. just know that the paint will burn off and those will get all rusted soon. if i bought those i would get the sand blasted and cermic coated for 50 more dollars. at least thats how much it would be here.
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
