rear end
Old 10-17-2007, 08:43 PM
1990mustanglx
1990mustanglx's Avatar
Default rear end
when i take sharp turns it sounds like a scraping coming from my rear end and when i stomp on my gas the rear make a pop noise and then when i let off it makes the same pop noise any idea whats wrong with it?
1990mustanglx is offline
Old 10-17-2007, 10:44 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: rear end
well, check U-joints and from there, if you can run it in the air on stands...try to use a auto stephascope to localize any noise...of course, it may be faint while the car is in the air, with no load but when you have pronounced problems, hopefully you should be able to at least hear something to help you narrow down the area from where the noise originates. also, make sure the backing plates are not rubbing on the inside groove of a brake drum.
mjr46 is offline
Old 10-17-2007, 11:13 PM
HACKGT350
HACKGT350's Avatar
yes it could be as simple as backing plate or it could be u joints
HACKGT350 is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: rear end
