quick question, see who can fill in the blank
RE: quick question, see who can fill in the blank
The blank should be filled with "front inner LH fender apron"
The ground bolt at the ECM location is for circuits 20 (CASE GND) and the shield of the PIP, SPOUT and IGN GND circuit wires. The PWR GND (ECM pins 40 and 60) location is at the LH fender apron, same location the battery (-) terminal wire to the frame is bolted to..... or...
ORIGINAL: Joel5.0
