Where is the ECT sensor and TPS sensor located?
RE: Where is the ECT sensor and TPS sensor located?
https://mustangforums.com/m_4026006/tm.htm
do this, from your other post, sounds like this is your exact cause, or the ecm has a bad ground or is shot
"i ran the codes with a digital ford code reader.. here's the codes. can they be related to the smoke?
o=
51, coolant temp. switch out of specified range
22, map sensor out of specified range
53, throttle position sensor input out of specified range
54, vane air flow sensor or air charge temp. sensor
35, egr pressure feedback, regulator check
67= neutral drive switch or circuit
r=
53, throttle position sensor input out of specified range"
o=
r=
