Intake problem
Old Feb 27, 2005 | 06:30 PM
JaxJags88GT's Avatar
JaxJags88GT
Default Intake problem
I dont know what the part is called but it's not the EGR or the TPS but it's attached to the front of the throttle body on the front with a plug in, well i removed it to put another one on a friend gave to me and the car wouldnt start, so i put my old one back on turned it over for a few and it started back up, well like a dumbass i thought it was a fluke, so i put the other one back on and it didnt start again, so i put my old one back on and the f***** wont start again, it's DOA this time, any ideas? and anyone know what that part is?
Old Feb 27, 2005 | 06:44 PM
91hatchgt's Avatar
91hatchgt
Default RE: Intake problem
It is called your IAC.. It is a sensor, and needs to be kept clean. I took mine off and cleaned it, reinstalled it and have had zero problems. Maybe you should try to clean it and make sure the push rod in it is not frozen, if so, get a new one, and make sure the connection is clean.
Old Feb 27, 2005 | 07:46 PM
JaxJags88GT
well that's what i was doing, i put the new one on, and the engine wouldnt start so i put the old one back on and it wouldnt start, anyway i took the battery terminal off and i'm guessing reseting the computer , but now it started up fine after leaving battery terminal off for 30 minutes. thanks for the input on what the part is.
djbigskrilla
Sep 20, 2022 01:04 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
