rebuilt motor
Old 02-27-2005, 08:25 PM
bluepony1
bluepony1's Avatar
Default rebuilt motor
i just rebuilt the motor and was just wondering if you are going to be able to turn the motor over with a breaker bar with the rods torqued down to the proper spec
bluepony1 is offline
Old 02-28-2005, 08:07 PM
69mach1377
69mach1377's Avatar
Default RE: rebuilt motor
If not...somethings wrong. Just make sure you have turned the oil pump shaft to oil up all the passages and holes.
69mach1377 is offline
Old 02-28-2005, 08:11 PM
619socalstang
619socalstang's Avatar
ifit is freshly ***. and well hand oiled it should turn preety eay but if the block was matchined to close it will be tight, ive done serval and used different machine shops until i found one i like and they machine the block to the spec of the pistons all piston have clearacne spec same withthe mains and rod check all your cleaences.
619socalstang is offline
Old 02-28-2005, 08:16 PM
roundman
roundman's Avatar
if you used assembly lube on all the bearings and the cam and lifters when you assembled the motor, and plenty of oil on the sides of the pistons, then you certainly should be able to turn it over with a breaker bar, especially with the spark plugs removed. if you can't turn it over, then something is bad wrong internally with the rotating assembly.
roundman is offline
Old 03-05-2005, 12:53 AM
bluepony1
bluepony1's Avatar
well with 1 connecting rod tightend down you cant move it with a breaker bar so something is wrong
Old 03-05-2005, 11:13 AM
TBIAgent69
TBIAgent69's Avatar
ORIGINAL: bluepony1
Your problem is probably that you mixed up your rod caps/rods.... First you need to make sure that the rod caps are on the right way (there is usually a machined area or number stamped on them, but knowing how cheap ford is there probably is no number) If there's a number stamped or cast in it, just match them up 1-8. If you're not so lucky, then start off by putting assembly lube on your rod bearing, and then putting one rod together on the crank with the cap on the correct way. If it turns easily, you're good to go. If not, take it apart and try another. There should also be a pattern that the assembly lube creates to show where it's siezing on the rod.
If you're positive you didn't mismatch the caps, then try plastigague and see if your clearance is too tight.
Hope this helps.
TBIAgent69 is offline
Old 03-05-2005, 11:16 AM
87mustang347
87mustang347's Avatar
is this an aftermarket bottom end, or did u just take your stock **** apart and now your putting it back together?
87mustang347 is offline
Old 03-06-2005, 12:17 PM
bluepony1
bluepony1's Avatar
took stock apart to replace pistons and rods
Old 03-06-2005, 03:39 PM
vfast
I ♥ Acer
vfast's Avatar
did it turn freely with just the crank in it?
vfast is offline
Old 03-06-2005, 04:59 PM
Tims 88GT
Tims 88GT's Avatar
did the piston go in the cylinder easy? can you turn the crank without any pistons on it? mine floated a little
Tims 88GT is offline
Quick Reply: rebuilt motor
