fuel injection question
Old Nov 1, 2007 | 03:38 PM
motorman524's Avatar
motorman524
MF Informant
Default fuel injection question
Can I use a 19 lb maf with 24 lb injectors and not run rich? I will be using an a9p pcm, gt40 p's with 1.7 rockers and an e303 cam. any help will be appreciated.
Old Nov 1, 2007 | 03:55 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
Default RE: fuel injection question
you need a tune if you do that. so....no
Old Nov 1, 2007 | 04:02 PM
motorman524
MF Informant
How much do tuners cost. cant really find one on the internet for a 91 mustang.
Old Nov 1, 2007 | 04:09 PM
stang8689's Avatar
stang8689
Just get the right one
Old Nov 1, 2007 | 04:11 PM
motorman524
MF Informant
the right one what? mass air meter. that will still need a pcm tune. i was trying to get around that somehow because tuners are expensive. I just cant find one
Old Nov 1, 2007 | 04:48 PM
schwindty's Avatar
schwindty
ORIGINAL: motorman524
YOu need a MAF calibrated to 24lb injectors......or if you have LOADS of time for learning a tuner like a twEEcer and a laptop....then you can go that route to figure everything out. From experience they are a bitch to learn it took me all winter to play with it to a pont whereI was comfortable baggin on it.
Old Nov 1, 2007 | 05:16 PM
primetime5.0's Avatar
primetime5.0
your 19's will support that setup.
Old Nov 1, 2007 | 05:40 PM
ahittz24's Avatar
ahittz24
ORIGINAL: primetime5.0
read again, he has 24lb injectors and a 19lb MAF, Just spend 125 and get a C&L meter for 24# injectors.
Old Nov 1, 2007 | 06:11 PM
motorman524
MF Informant
I could always use the 19's though if they will work. I was under the impression that upgraded injectors were needed with a hci swap. If I dont need to upgrade that would be great.
Old Nov 1, 2007 | 06:24 PM
schwindty's Avatar
schwindty
19s are good for about 280-300 at the wheels. The 300 mark is pushing their limits though.
