Cam clearance
RE: Cam clearance
88 was the old car. I am building a 93 mass air. I am looking for A LOT of low end. I had great power through out the rpm's with my old setup with a stock cam. I know the e cam is great for low end so thats probably what i will go with as long with the 1.7's.
[align=left] [/align]
RE: Cam clearance
man... spend the ~200 for 1.7s on something else...
im in the process of putting the valve train in my car... i have an 800$ budget... and i was going to get 1.7s... but w. stock heads... its just not gonna be worth it... u might get a little gain... but their still stock heads
ur getting valve springs right?
e cam has some low/mid range power yea, buddy used to have one in his fox... but there are better cams out there
RE: Cam clearance
I made 234 rwhp on a stock motor, stock heads, and a stock cam. I am gonna use the stock heads, just cause it is the way i wanna go. I am wanna go with the 1.7's. I've ran my hole setup idea through a bunch of people and they all say it will work.
RE: Cam clearance
ORIGINAL: SuperFox88
[align=left][/align]
RE: Cam clearance
but w/e man... if ur gonna be that stubborn... "bottom line. e w. 1.7s or f w. 1.6" then you obviously dont need anyone heres opinion... seems like ur idea is set in stone... but pft... what do we know? i mean mjr owns a ****ing shop... and his car runs 11s(right?, if not its faster...) and im doing my cam/valve train RIGHT NOW. and have spend hours upon hours looking into it... but u seem to know what ur doing... flip a coin...let F be heads, and E be tails... i suggest a best outa three
RE: Cam clearance
ORIGINAL: dimebag
sorry dude but theres no ****ing way... stock claims 225 AT THE CRANK, your telling me you some how gained hp thru ur drive train? something, actually more then just something is NOT stock...
RE: Cam clearance
idk what u say... stock parts... u can play w. timing, fuel pressure, etc etc etc etc all u want... STOCK it wont do that... unless you did some port , ok alota port work... and if thats the case, and ur not telling us ur exact set up, how should we suggest a cam???
dont feel bad mjr, mines apart too, lol
RE: Cam clearance
Personally i would not go with a letter cam either....They are alright cams, but you can do better. Research a little bit more. Alphabet cams are "outdated" persay, there are multiple other cams you can go with if you looking to get the most power possible with your setup. Research.
