AOD with a carb
Old Nov 5, 2007 | 05:05 PM
hillbilly pony's Avatar
hillbilly pony
Default AOD with a carb
I am building my AOD now and i was wondering if anyone knew of any pics of the install with the lokar kit for kick down. unless anyone has a kindergarden style of explanation. Maybe im just getting all carried away over nothing.
Old Nov 5, 2007 | 05:25 PM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: AOD with a carb
i dont have the "lokar kit" but i can post some pics of my kick down setup, (im also running acarbed 5.0) if you want to see it. its pretty simple to hook up, a couplebars conected to the throttle on carb and a little cable going to tranny
Old Nov 5, 2007 | 06:15 PM
ddeaton66's Avatar
ddeaton66
Setting up the same......pics would be grand for me as well
TIA
Old Nov 5, 2007 | 06:39 PM
Joel5.0's Avatar
Joel5.0
FYI........ http://www.shockley.net/Holley-AOD.asp
Old Nov 5, 2007 | 06:43 PM
hillbilly pony
I would definitely like to see the pics. How do you like the set up. is it consistent
Old Nov 5, 2007 | 07:33 PM
FLcracker9's Avatar
FLcracker9
Thats a pretty good article. I ran the Lokar cable on my F150 to the lower hole onmy Demon carb, and the "throw" on the carb is shorter than the throw on the TV lever, so the TV valve did not open all the way under full throttle.The distance from thecenter of the butterfly shaft on the carb, to the cable attachment, should be the same as the distance from the center of the TV shaft, to the end of the lever where the cable attaches on the TV lever. Clear as mudnow?
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
