Block
Old Mar 3, 2005 | 07:09 PM
stanglx2002's Avatar
stanglx2002
Default Block
after im done with my suspension i want to build a motor. Im wanted to know what is a good block that i can bore to a 331 stroker? I want it to handle about 350-400 N/A and then a SC later. Also is Hawks Racing parts any good or not?
Old Mar 3, 2005 | 07:42 PM
Aixtreme89's Avatar
Aixtreme89
Default RE: Block
A stock 5.0 block will be able to handle up to 600hp to the crank before failing. It can be stroked to a 331. stroking it and boring it .030" over. You can even go up to 349 if you use a longer stroke and bore it to .040" Stick with a 331 the connecting rod pin stays out of the oil rings in the piston. Oppossed to how 347s have the pin intercepting the oil rings causing more oil consumption. I bought a 331 Comp Hawk crank and rods. and probe pistons but I dont know how they run. I have it on an engine stand still. Just dont go through D&D motorsports I had to many problems with them. I heard good things about DDS, try them.
Old Mar 3, 2005 | 07:50 PM
stanglx2002
Default RE: Block
Good it can handle 600HP im looking for about 500HP when im done. I can get stock blocks easy
Old Mar 4, 2005 | 02:17 AM
primetime5.0's Avatar
primetime5.0
Default RE: Block
ive always heard 500 hp on a stock block is pushing it
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mustangheaven
Sep 29, 2015 11:00 AM
wraith777
Sep 28, 2015 10:49 AM
