no start problem
Old Nov 11, 2007 | 12:20 PM
topless91gt's Avatar
topless91gt
Default no start problem
I replaced my TPS and set the voltage at .99. I started the car and let it run for about 2 minutes. It gradually started running worse and then missing. It finally went dead and now it won't start. It is firing, the fuel pump is coming on when I turn the key. I even put the old TPS back on and tried unplugging it. Still wont start. I'm getting about ready to slap acarb on it and forget it.
Old Nov 11, 2007 | 12:52 PM
Joel5.0's Avatar
Joel5.0
Default RE: no start problem
The fuel pump might be working, but is it producing the required pressure ?...... Spark present at the coil ?.... if you spray some carb cleaner down the TB bore, will it start and stall?....
Old Nov 12, 2007 | 12:52 AM
topless91gt
it is firing at the coil and yes she will run as long as i am spraying the carb cleaner to her. Going to get a noid light tomorrow to see if the injectors are firing. If they are it looks like its time to pull the fuel filter and see if im getting gas there. I'll keep you posted. Thanks alot!
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
