3 quick ?s
Old Nov 12, 2007 | 03:54 PM
ncpantherfan's Avatar
ncpantherfan
Default 3 quick ?s
I posted this in the general section, but I think I should have posted it here, so I am posting it here. I will try and delete the other post.
95 GT vert reverse lights were not working, I looked under the car and I think I saw the auto trans wire harness, so I think this car had the swap done before I bought it.
Can Iswap ina manual trans harness to get the reverse lights operational?
How can I tell if my car has keyless entry from the factory?
Is there aweb site where I can input my VIN to see how this car was equiped from the factory?
Thanks guys. Just starting the long process.
Old Nov 12, 2007 | 05:14 PM
Dave5point0's Avatar
Dave5point0
Default RE: 3 quick ?s
A. Who needs reverse lights
B. Thats a good question, i'll look up where the keyless brain is in a 95 vert for you
C. I'm sure adder or mrj can direct you in the right direction because i don't know the site that they have to look at vin #'s (they found out mine was origanally a 4 banger converted to 5.0)
Old Nov 12, 2007 | 05:55 PM
ncpantherfan
The state requires reverse lights on the saftey inspection.
Old Nov 12, 2007 | 07:31 PM
1990boostang's Avatar
1990boostang
Does your turn signals still work. My turn signals quit working and my reverse lights I have checked the fuses but im stumped I dont know what it could be.
Old Nov 12, 2007 | 09:17 PM
ncpantherfan
My signal lights work. There is nothing hooked up to the reverse switch n the trans. I am pretty sure it was an auto. The only thing hooked up to the trans is the speed sensor. I have traced the harness, and it looks like it will hook right up, just looking for someone to say you are correct before I start looking for one. Will a V6 harness work as well, or does it have to be a GT harness.
Guess that makes 4 questions.
Old Nov 13, 2007 | 03:59 PM
Dave5point0
Saftey inspection, whats that? Sounds gay. Is it a rebuilt title car and you have to get it inspected, or a state wide inspection? Just hook up a switch for the inspection to turn the lights on for the test.
(I have no reverse light bulbs)
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
