A/C Delete
A/C Delete
A/CCompressor went out on my '90 GT so I figure Ill just go ahead and delete it, save the weight and the strain.
Anything Special I Need To Know About Removing it? or just un-bolt and remove?
RE: A/C Delete
you can get a powersteering pump relocation bracket from ford racing... it deletes your A/C and moves your powersteering pump to the A/C location. Obviously.
I'm not sure if you can just remove the A/C compressor and call it good or if you need the bracket so you can put the belt back on properly.
RE: A/C Delete
yeah!!! if there is still freon in the system......go get it evacuated/ reclaimed...don't do what most people do and depress the schreador fitting and let it **** into the atmosphere[&:]
RE: A/C Delete
yea and considering its a 90 model it probably has r12 and thats a serious fine, i cant remember if its a felony or not. i know that if you ever went to change it over to 134a at a shop they have to store it in a tank to either recharge r12 systems, which is unlikey, or dispose of it properly, which i dont know the technique. but if i was you id just leave it all there, and run a short belt. no need to move anything. call autozone and ask them for a belt that bypasses a.c. they should have a listing.
RE: A/C Delete
ORIGINAL: 94snake
RE: A/C Delete
oh i dont know what im talking about? thats why ive done it when my compressor locked up? the belt will not rub itself. you have to re-route it. dont correct me if YOU are in fact the one who doesnt know what theyre talking about.
