block question
Old Nov 14, 2007 | 11:32 AM
GaryBisiniere's Avatar
GaryBisiniere
Default block question
i currently have a 306 block and my question is will my block need more work done to it to put a 331 kit or 347 kit in it? or can i just put it in?
Old Nov 14, 2007 | 11:49 AM
Joel5.0's Avatar
Joel5.0
Default RE: block question
331.... not really.......347 just a little clearancing.
Old Nov 14, 2007 | 03:40 PM
GaryBisiniere
so will it require more machining to put a 331 or 347 kit in?
Old Nov 14, 2007 | 04:14 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
no, you can use a die grinder and clearance the bottom of the piston skirts in the bore where the rod throw would interfere with skirts also you really need to have the pistons test fittted to the bore for out of round and or taper cause if you throw .030 347 pistons in a block already used/ bored .030 you may have inconsistencies that may or may not cause compression or blow by issues or wear problems...that's why when boring a block the machinist always wants your pistons before boring so the bore can be tailored to your pistons
Ipaman
Sep 22, 2015 07:01 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
96stang3.8
Sep 10, 2015 06:42 AM
Sep 8, 2015 05:21 PM
