first time doing a clutch help!
RE: first time doing a clutch help!
pull exhaust(mid pipe)
pull drive shaft(12mm 12pt bolts(4) at the rear, slips outa trans)
jack under trans, pull the crossmember
unbolt the trans from bell housing(4 bolts)
unhook clutch cable.
unbolt bell housing(6 bolts)
unbolt clutch press. plate
reverse for install
reverse for install
its fairly easy, i had to drop the tranny a week after doing the clutch because the seal on the input shaft of my t-5 tore and leaked tranny fluid into my bellhousing. my dad had other sidework to do so i was on my own and did it myself. its easier then you think.
make sure you get a clutch alignment tool from somewhere, otherwise your gonna make it tough on yourself, and if you wanna do it right, send your flywheel to get resurfaced. take the shifter out of the tranny too before you do everything else. after that its just take it apart, put it together.
mungodrums
10-07-2015 04:01 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
