clutch and cable recomendations??
I know all clutch cables are pretty much the same but anyone have anyrecomendations?? also I am debating weather or not to get a new clutch while im at it... whats the best clutch for a daily driver/ friday night drag...
RE: clutch and cable recomendations??
Centerforce Dual Friction will be perfect for what you describe. As far as a cable, get the Steeda cable, quadrant and firewall adjuster. You'll be glad you did.
ORIGINAL: PRO50SC
We have done a lot of research on clutch cables, buying and testing almost every different cable on the market we could find. We have found after all this investigation, that the OEM Ford Clutch Cables are the best quality cables available. They have a multi-material, layered construction that provides better heat, friction and collapsibility protection than all the aftermarket cables we dissected. With that in mind, we have begun selling all year ranges of factory cables, for those customers that demand a cable that will last.
Myself I use the OEM cable, Steeda firewall adjuster and quadrant
