Idle problem
Okay so i just got finished installing a professional products egr plate and throttle body, both 70mm, and got everything all hooked up, and the car idles at like 600rpms, and if i get on it, and come to a stop, it will just die, any suggestions
600rpms is a pretty low idle, could there possibly be a vac leak somewhere? Does the car die when you drive it regularly and then stop, or only if you get on it and stop. Anychance you can check the fuel pressure?
I dont know a lot, but im giving my 2 cents <3.
yea it should be somewhere around 900, no vacuum leaks, yea it dies pretty much either way i drive it..and fuel pressure is fine, just put on a walbro 255lph pump, and kirban afpr, and pressure is good...i have a feeling it is something not adjusted right with the new throttle body plate
Ryan, what is the TPS set at? It doesn't come preadjusted on that t/b? Also, you may need to set the base idle up (adjusting screw under the t/b)and then set the TPS. I ran my stock mass air for quite a while when I upgraded to the same t/b and plate you have. That shouldn't have anything to do with it. What intake are you running?
Hey Bernie, I have no idea what the tps is set at, or where to check it. and i tried to adjust the screw down there like the directions said...it has a t-15 screw in it, and it is coated with some yellow stuff? locktite? and when i tried to adjust it, i only managed to break my torx bit[:@]... i am still running the stock intake too
Hmmmm, you shoulda waited in the upgrade. The stock inlet is quite a bit smaller on the intake. Not really gonna get much outa the new parts. I'm in Dela this weekend, otherwise I would help ya out. It's not that hard to adjust. There should be some links in our tech section on the sublect.
