Listen to this GUYS!!!!
So, today i took out my noble 85 gt t-top steed out for a prance...and as i came to a stop sign a 94 lt1 camaro with pipes and cheater slicks was in front of me, he revved his car up and i returned with a burble or two, anyways i followed him for a bit both of us showin each other wat we got for power, so we get to a corner and he revs it up and dumps it slidin out aroudn the corner, i downshifted from 3rd to secodn and ran his *** down, we approached a mild corner doin 90 both of our cars tires squealin, i ran from 2nd to 5th wide open, the only mods to my car are a 3;73 rear, heads were boiled and new crankshaft, holley carb, and ford motorsport springs pullies, and a hurst short throw, i found it kind of sad that a almost stock 5.0 t-top stang i ahd them off while racing, could run with/pull a lt1 camaro..i loved eevryminute of it.
Now heres where i get a problem...i come to the next light and my car overheats, its overheated b4 just from drivin it for an extended period of time, i lose all my radiator fluid, and iw as wondering what u guys think it is? is it a thermostat? if so waht brand do you suggest? also my tranny began leakin a small little puddle of pink fluid, only does that when the car gets hot to or i powershift i think...is it a seal? its dripping form the back of the tranny..thansk guys please help me out..thakns in advance!!!!
RE: Listen to this GUYS!!!!
My first suggestion would be thermostat for the overheating. Your transmission leaking problem is going to be your tailshaft seal. If it only does it when you are beating on it then it may need a tail shaft bushing also. When you do the seal see how much play you have in theoutput shaft.
maybe pick up a radiator cap too!!! if the pressure relief valve is bad not bleeding off pressure at the right psi it'll build and raise the boiling point temp of coolant and car could then overheat and puke it's guts everywhere...cheap easy try too!!!
tailshaft seal is a cake job. Jack the car up, unbolt the 4 bolts from the driveshaft, pull the driveshaft out. Take the old seal out, put the new one in. Then put the driveshaft back in & put the 4 bolts back in.
Make very sure you put some trans fluid or grease on the driveshaft yoke & the seal before putting the driveshaft in. If you don't, you'll probably damage the seal from lack of lubrication. The only tools you should need are a 12mm 12point wrench & maybe a screwdriver to get the old seal out. (pry around the outside of the seal) Maybe a small hammer to gently tap the new seal in.
I'd say the overheating is probably from the thermostat. Fan could also cause that. Got a fan shroud on it?
Yea, check the cap and thermostat..... good to here that you were keeping up with an f-body, no offence but i'm guessing he couldn't drive very well or it was a v6(lol), i'm not sh*t talking, i just know that those cars are typically damm fast, my first 5.go had problems with alot of f-body cars. I ran a 11.54 once in perfect conditions but normally a 12 car for sure, and there were many t/a's and maro's that had a bit of work and would run me down if i had street tires with a-hella a-lotta spin, good to here you ran with him though
ORIGINAL: Dave5point0
^^^lol, any 300+ c.i. car that is beat by a crapilier needs to be sold a.s.a.p. I'm sure that most of the cars that were giving me trouble were heavy on the mods because i lived less then 5 miles away from F.L.P. (finish line performance outside chicago) which i believe is top 10 in the country for tuning f-bodies, so i was getting shafted because i would be on my way home from work on street tires and without my timing way retarded, and a recently tuned f-body that just got 5g's dumped into it would be on its way towards the highway to go home and they decided to phuk with me and feel good about themself.
hey foxgt, you ever get your car back together after that ditch jumped out infront of you?????
