65mm throttle body Up grade??
RE: 65mm throttle body Up grade??
The Editor-In-Chier of "5.0 Mustang and Super Fords" Steve Turner disagrees with you Jasperstang308, could you point out where exactly you disagree with him..
http://www.amazon.com/gp/reader/0760...51983-9707811#
Steve Turners book, page 26
...installing too large an oversized throttle body can hurt performance, particularluy torque
...this is mostly true regarding (page 27) naturally aspirated 5.0's.... torque loss
...tb shouldnt be larger than your maf... you want to create a funnel for the air...
[IMG]local://upfiles/84695/DAC7EE0E5E254B019534F628A9093669.gif[/IMG]
we had this discussion before but you didnt reply to this info, Im curious as to what you have to say regarding the article cited.
Of course "on paper" concepts dont fly 100% of the time in real world and I have no doubt to your experiance with the seemingly (on paper) mismatched components working well, and I love the type of engineering spirit that you try something, make it work and make it work well, that is the pioneering spirit of America after all!
However I think we are going for the rule here, not the exception. We want to discuss and generate an answer that will be correct most of the time: what components match a config: when & why.....
ORIGINAL: nacanitihs
actually i believe jthorn is correct. you lose air velocity if you have a TB thats too large and an engine that doesnt demand that amount of air. a 65mm will be a good upgrade for a stock engine w/ minor bolt ons
jasper do you have any support for your answer?
on 5.0 it goes: From large--The world, air filter, MAF, TB, intake, (smallest here)heads, <ign event>(gasses expand now getting larger)headers, collecters, exh system, world
As always you want to try to match components to make an optimized system.
WE were talking about this issue here
https://mustangforums.com/m_4200328/tm.htm
It made me think of an article I read a few years ago and promped me to remember what it was exactly:
"Cam Truth by Buddy Rawls"
http://www.wighat.com/fcr3/camtruth.htm
yea you mentioned that from another thread. 2 of the quotes above are direct quotes from jay. i will let you know when i actually do it myself. it should be a little after christmas.
Buddy Rawls knows what he is talking about.
A 75mm TB is a waste of money on a h/c/i car.
Think of popular intakes. Think how the Holley Systemax necks down to 65mm a few inches in it's "75mm opening". Makes you wonder how you are going to gain
Be careful on what a bigger throttle body gives you.
Some call it:
...More throttle response
Some call it:
...Touchy throttle in part throttle situations.
Many forget where the "bigger is better" throttle body theory is coming from.
It comes from those that live at the drag strip, not on the street.
I haveNEVER seen a real gain from a 75mm TB on a h/c/i car.
Some call it:
Some call it:
Show me a 302 that can flow 700 cfm
Because that is what a typical 75mm TB flows.
If you have a throttle body that flows 100% of the engine's capabilities at 60% opening, you lose throttle control advantage.
5spd i believe you know where i got my info from if you want the link i will send it to you. i know the comment that i quoted from joel was on a completely stock car and it actually benefited from the 80mm tb
so its up to you guys. you can either stick with what has been told or try something different. i personally am going to be different. i am picking up a stock 302 this weekend. it needs a few things. but I will buy the parts needed to put it together and will put on a larger tb and bigger induction so we can test this theory
what do you say?
what do you say?
ORIGINAL:
what do you say?
what do you say?
Hmmmm thinking here, what would be the best way to prove your results? Dyno comes to mind but can it measure from off idle -> on?
Perhaps at the track you can make 2 runs, change the TB then make 2 more runs and look at your short times, this might be a bit better.
However, I believe that the crux of the question here is "how do I select the best TB for street+strip (mostly street) that flows the cfm's that my engine can demand also keeping supurb stoplight to stoplight driviablity:
(From stoplight to stoplight druning a commute to work on a conjested street, this indicates much activity "just" on the throttle, incrimental steps where the TB blade would spend time "just" cracked opened, a hair more, a hair less)
ORIGINAL:
what do you say?
what do you say?
ORIGINAL:
what do you say?
what do you say?
is thi hurting me or not
ORIGINAL: Jasperstang308
depends on who you ask
[sm=massbounce.gif]
