New Project, whats ur opinions???????(long)
Old 03-07-2005, 09:05 PM
5.0carlo
5.0carlo's Avatar
Default New Project, whats ur opinions???????(long)
The car is a 90 LX hatchback, Silver with tinted windows, 5-speed, UPR shifter. ON the inside Im adding NR automotive white faced gauges that glow at night like the 03 cobra ones. Outside Im lowering the car with Ford racing springs and adding 03 cobra rims (car already has 5-lug conversion). Engine wise its a 302 bored .030 over with a lunati cam same size as E303, motor has probe forged pistons. Im adding AFR 165's, BBK SSI intake, BBK 70mm TB, BBK 75 mm MAF, 30lb injectors, BBK CAI, Ford racing ALuminum Radiator, electric fan, MSD ignition, and coil. BBK long tubes, matching short x-pipe, with no cats, flowmaster 2 chambers. Aluminum driveshaft, energy suspension , motor mounts and transmisision mount. BBK caster-camber plates. Itll have a strut tower brace, Ford Racing 9mm wires. Adjustable fuel regulator. Ill have a chip burned for it. And it will have 3.73's out back. This car will be my friday night car that ill use for street racing. Im just little for a lil criticism on the parts, and oh do you think its possible to run with the new cobra's with that combo......even stock? Thanks. Oh and Ill have a 190 lpg fuel pump.
Carlo
oh yeah and next motoe for it will be a DSS AFR headed 331 with a Kenne Bell 2.2L blowzilla, running about 12lbs of boost.
5.0carlo is offline
Old 03-07-2005, 09:08 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: New Project, whats ur opinions???????(long)
well it looks to have alot of mismatch parts.. with 165's a 65mm tb and 24's at the most also the intake IMO doesn't match the heads
vfast is offline
Old 03-07-2005, 09:16 PM
stanglx2002
stanglx2002's Avatar
i agree with vfast you need some parts that match
stanglx2002 is offline
Old 03-07-2005, 09:21 PM
5.0carlo
5.0carlo's Avatar
So maybe a GT-40 intake, 65mm TB , and 24lb injectors would work out alot better huh, I was actually thinking thart way, at least id be able to keep the bottom intke for when i get the KB. Thanks for the info guys.
carlo
5.0carlo is offline
Old 03-07-2005, 09:23 PM
stanglx2002
you could just port the intake bigger when you got the blower
Old 03-07-2005, 09:25 PM
bobby
bobby's Avatar
get an eldelbrock performer intake
bobby is offline
Old 03-07-2005, 09:26 PM
stanglx2002
for what he wants i would go with the preformer RPM
Old 03-07-2005, 09:29 PM
bobby
bobby's Avatar
ORIGINAL: stanglx2002
thats what i mean
bobby is offline
stanglx2002
O ok
Old 03-07-2005, 09:33 PM
5.0carlo
5.0carlo's Avatar
Yeah thats a good intke, the only reason I would second guess it is a friend of mine has an RPM with an E303 cam and it doesnt pull that hard in the bottom and his car is almost exaclty like the one I am building with mino differences. Plus I was reading the new 5.0 and super ford mag and they did an intake test in there with 5 intakes.
5.0carlo is offline
Quick Reply: New Project, whats ur opinions???????(long)
