car died....need some help...
Old Nov 24, 2007 | 01:50 AM
redemption's Avatar
redemption
Default RE: car died....need some help...
LOl ya mind had that problem but it would still start my blinkers wernt working, that pig tail was slightly off . so i did what you did and zip tied that f##$er =P and wadda bing blinkers working
Old Nov 24, 2007 | 08:39 AM
DoctorD415's Avatar
DoctorD415
I dont think its the battery or altenator because it would not start by jumping and mostly everything went on(lights, electric fan dash, fogs) it just wouldn't start.There wasnt even a clicking at the solenoid.
Old Nov 24, 2007 | 10:09 AM
DoctorD415's Avatar
DoctorD415
just pulled some fuses and found a 15 amp blown, it was the one right in front closest to the driver. Does anyone have a diagram of what fuse is what? Its an 85 gt
Old Nov 24, 2007 | 02:21 PM
RedHatch92gt's Avatar
RedHatch92gt
check battery terminals...see if loose....if no start no crank no lights no prime ...or nothing....also check ignition fuse...if there is crank or lights then sounds like u need a multi meter and need to trouble shoot
Old Nov 24, 2007 | 02:25 PM
RedHatch92gt
the ignition fuse should be on the bottom row...i belive 2 one from the left...i have all my gauges ran through that 1 and when i shorted that fuse aith all the gauges the car shut completly off ...lights, and everthing...wouldnt even crank...but then i saw i changed fuse and bam that car fired right up and then i smoked the tires cause i was so happy.
Old Nov 24, 2007 | 08:22 PM
splash21's Avatar
splash21
i had a problem similar to this. i was driving to work and all of a suddon nothing. the lights worked but nothing in the cabin or engine would work. turns out it was a fuseable link in the ignition circuit. i jumped the starter solenoid to the battery and got it to fire up and drove it about 200 feet to a shop and had them test while i went to work. i was about a 5 min walk from work when it happened. they found it and replaced while i was working and had it back by lunch. try testing your ingnition and starter circuits
Old Nov 24, 2007 | 09:44 PM
DoctorD415's Avatar
DoctorD415
ya it was a fusible link, somehow the wire got cut. I checked it all over and got everyone back to work. Thanks for all the help.
Gregz
Oct 18, 2022 03:52 PM
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
