HOW DO YOU CLEAN OUT WATER IN HEADLIGHTS?
Old Mar 8, 2005 | 07:32 AM
Dejavu's Avatar
Dejavu
Default HOW DO YOU CLEAN OUT WATER IN HEADLIGHTS?
Exacly what the tittle says, lol!
I just took out my headlights and I can't open them completely, theres water drops inside of them, how do I clean those out?
Thanks !
Dejavu
Old Mar 8, 2005 | 07:57 AM
87 hatch's Avatar
87 hatch
Default RE: HOW DO YOU CLEAN OUT WATER IN HEADLIGHTS?
i dont think there is a way to open them. you might just have to try sticking a rag inside and moving it around other wise if you have an air compressor you can try to blast some air inside and dry it out.
Old Mar 8, 2005 | 09:46 AM
mustang8719's Avatar
mustang8719
What I did with mine was drilled small holes in the bottom of the clear part of the headlight.I drilled them so you couldn't see the holes when the headlights are in on the bottom edge by where it meets the bumper.
Old Mar 8, 2005 | 09:52 AM
bobby's Avatar
bobby
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ GOOD IDEA
Old Mar 8, 2005 | 09:59 AM
mustang8719
Once you drill the hole you will never have water in there again.The only way you will have it in there again is if it drounds in a lake.
Old Mar 8, 2005 | 10:06 AM
bobby's Avatar
bobby
LOL!
Old Mar 8, 2005 | 10:40 AM
mustang8719
I did mine 6 years ago and haven't seen a drop of water since.
Also to clean and dry them good denatured alcohol works good to dry it out.
Old Mar 8, 2005 | 11:33 AM
stanglx2002's Avatar
stanglx2002
look around the headlight to make sure all the seams are sealed and if they are not seal them bc i had the same problem and it was a seam not sealed
Old Mar 8, 2005 | 02:53 PM
Dejavu's Avatar
Dejavu
I love you guys, you guys hit both threads =D =D shows me you guys care!!! hehe
Man, I want to show you guys pics of the car...
I'm gonna try the alcohol thing, whichs is the denatured one???? the ones in white bottles?
Also, I might drill the hole too, what size bit did you use, and do i run a big risk of cracking the headlight????
Thanks guys!!
Old Mar 8, 2005 | 02:59 PM
mustang8719
You can use the smallest bit you have.The lens is plastic and should not crack.The only way it would crack is if you didn't control the drill and the drill cracked it.Look for denatured alcohol on the label.
