clutch cable
Old Nov 27, 2007 | 05:12 PM
945LSTANG's Avatar
945LSTANG
Default clutch cable
Right now i have the steeda kit and this issue came up: Im driving to school this morning and ithad to be around 30* outside. im almost there when i push in my clutch and hear an odd pop sound from the general direction of my bellhousing, andmy clutch pedal then felt very weak. i was no longer able to shift gears because i wasnt able to fully disengage my clutch.i was somehow able to get it back home by keeping it in first (i live very close toschool).when i got home itook off the clutch fork shield to see what was up and i find this:
what could have caused this? anybody else have trouble with the steeda cable??
btw....whats a different brand that you guys have had better luck with?
Old Nov 27, 2007 | 05:21 PM
89mustangfive0's Avatar
89mustangfive0
Default RE: clutch cable
i've had this happen to me 2 times but with a upr cable and a summit cable. i was told multiple things such as the geometry of the quadrant is angled one way to much or something i have not a fukcin clue..i've been running my non adjustable cable threw the middle loop of my quadrant and it works good
Old Nov 27, 2007 | 05:25 PM
golden_eye's Avatar
golden_eye
I still have all my stock clutch stuff (probably not much longer though) so I have no first-hand knowledge. That being said I have seen a lot of people say that the OEM Ford cable is one of the strongest ones you can buy.
Old Nov 27, 2007 | 05:32 PM
89mustangfive0
it works good but its not adjustable and i have the quadrant for the adjustablle cable but i snapped 2 i hear it creak and then sooner or later i hear a pop and then the pedal gets soft. funny i was just about to buy steedas cable last night to.
Old Nov 27, 2007 | 06:24 PM
86 5.0L's Avatar
86 5.0L
ALL aftermarket/adjustable cables are crap compared to the OEM cable, stronger and thicker
Old Nov 27, 2007 | 09:24 PM
WhiteWindsor's Avatar
WhiteWindsor
You say you have the steeda "kit", so i'll assume the quadrant and adjuster. Yes, the oem cables are the best and you can use them with the steeda stuff with minor modifications. But still the cable should not have just snapped unless it is a factory default. If you have a multiple hook quad, be sure your on the right one. Other than that i would say your quadtrant is putting cable in a bind of some sorts. It has to be lined up right and shimmed if neccesary.
Old Dec 2, 2007 | 09:19 PM
945LSTANG's Avatar
945LSTANG
i know its been awhile but ive been very busy.
what do you guys think about these??
http://www.autopartswarehouse.com/se...7011+1616+5762
Old Dec 2, 2007 | 09:38 PM
945LSTANG's Avatar
945LSTANG
bump
nobody has any first hand knowledge on those cables?
Old Dec 2, 2007 | 10:29 PM
86 5.0L's Avatar
86 5.0L
ORIGINAL: 945LSTANG
bump
probably because its a no-name brand lol, if you REALLY want an aftermarket cable go steeda, ford racing, etc, I still recommend an OEM cable though
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
Explosive
Oct 2, 2015 07:45 AM
junior04
Sep 28, 2015 10:53 AM
