pulled head
Old Nov 29, 2007 | 12:41 AM
84conversion50's Avatar
84conversion50
Default RE: pulled head
so dont just replace the valve?
Old Nov 29, 2007 | 12:47 AM
84conversion50
will these fit D2TEAA there for a ford 390 but there brand new and have everything with them for 30$
Old Nov 29, 2007 | 07:21 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
ORIGINAL: 94 G STANG
I dont know about the casting number but gt40 or any ford 5.0 head is interchangeable between 5.8, it might turn out that your 5.0 has 351 heads, difference between a 302 and a 351 is the deck height of the block.
Not true[&:]...the 351 uses 1/2 head bolts and to interchange 302 heads to a 351 the smaller diameter holes on 302 heads 7/16 to be exact need to be drilled out th 1/2 inch to due such a swap...that's to say the block is a 351
Old Nov 29, 2007 | 07:23 AM
mjr46's Avatar
mjr46
ORIGINAL: 84conversion50
no not in the least!!! they are for a FE block not a windsor based block ...completely different style you need 302 headsor 351 heads depending on what your block is
Old Nov 29, 2007 | 09:25 AM
my77stang's Avatar
my77stang
come to think of it, if you heads actually say 351 on them i would tend to think they are early heads (69-74) because after that the castings were the same.
once you have the head off, look under the intake runner and find the casting number, if its a C9 or a D0 you want to get those heads fixed. you'll also want to get hardened exhaust seats installed in both heads (hell this could be your problem with bad compression if it pounded the crap outta a unhardened cast iron seat in the head)
Old Nov 29, 2007 | 03:25 PM
84conversion50
so why just one cylinder? im going to get them professionally rebuilt but how much are seats?
Old Nov 30, 2007 | 11:32 AM
mattkoly's Avatar
mattkoly
Seats are inexpensive, I've hear that the viton umbrella type are the best. If you dont' already have this type on there some machining is required, but you are getting them worked on anyways.
Old Nov 30, 2007 | 12:10 PM
my77stang's Avatar
my77stang
^ bad post, bad.
SEATS are hardened steel and are about 10-15 bucks each to install - you need 8, the intakes do not need to be replaced.
SEALS are what mattkoly is referring to, and umbrella's are the WORST seals you can get. make sure the shop that does the work installs a positive style valve seal, the exhaust seals should be poly-acyrlic or viton - nitrile will get hard very quickly and not seal properly.
of course, we're basing the seat machining off the fact that these are "early" 351w heads. WHAT ARE THE CASTING NUMBERS?
Old Nov 30, 2007 | 02:23 PM
84conversion50
i dont remember its like -102032939483 degress outside. it started with 3g maybe 3g96?
Old Nov 30, 2007 | 08:35 PM
84conversion50
i found a pair of heads. the casting numbers are E7TE PA T8 and E7TE PAT52 does that mean its 2 different heads? i havent seen them yet thats just what he told me they were. will they work?
