pulled head
Old Nov 29, 2007 | 12:01 AM
84conversion50's Avatar
84conversion50
Default pulled head
so today i pulled my drivers side valve cover off to adjust a rocker. now i look at it it says 351 on the right side and on the left a 4 digit casting number cant remember it it was 3g**. so this makes me think about whether its a 302 or 351w. it has a burnt exhaust valve and i need to get that fixxed. i was gunna swap for e4 or gtp40 heads but now im wondering it that will work.
Old Nov 29, 2007 | 12:11 AM
94 G STANG's Avatar
94 G STANG
Default RE: pulled head
I dont know about the casting number but gt40 or any ford 5.0 head is interchangeable between 5.8, it might turn out that your 5.0 has 351 heads, difference between a 302 and a 351 is the deck height of the block.
Old Nov 29, 2007 | 12:12 AM
84conversion50
well whats your reccomendation then? find the same head and just replace that side or find 2 different ones and swap them both. and right now i have roller rockers in them. would it be a good idea to swap those over to the new head?
Old Nov 29, 2007 | 12:15 AM
Maxwelhse's Avatar
Maxwelhse
Why not just replace the cooked valve?
Old Nov 29, 2007 | 12:18 AM
94 G STANG's Avatar
94 G STANG
it depends on your budget, and what you want to do with your car. Do you want it back up and running again? just take the head to a machine shop and have em do a valve job. Id do more research on the heads you have on now maybe they are ported etc.
Old Nov 29, 2007 | 12:23 AM
adumb's Avatar
adumb
i'd also check the block numbers and see what you are actually looking with.
Old Nov 29, 2007 | 12:24 AM
84conversion50
well i would do the valve my self if it was worth my time. there ported and polished heads. it runs fine just crap mileage
Old Nov 29, 2007 | 12:28 AM
94 G STANG's Avatar
94 G STANG
your not running right if you have crap mileage.
Old Nov 29, 2007 | 12:30 AM
84conversion50
cylinder 8 only gets 30lbs of compression so its missing alot. burnt exhaust valve
Old Nov 29, 2007 | 12:37 AM
FoxGT's Avatar
FoxGT
ORIGINAL: 84conversion50
the windsor heads are reversible. You can use two drivers side heads on a car, or two passenger side heads. If you compare the left & right head, they are both 100% identical.
Just find out what head is on it & if it's had any work done to it, then replace it. If it appears to have work done, replace them both.
