ECT sensor...
well I still have the missing problem, But I still have a couple of question.
when I drive faster and stop less the car doesnt do the missing problem. Its wierd when I floor it or give it more gas than normal it doesnt miss.. Why is it doing that(not missing when I drive spirited/giving more gas)?
This leads me to believe that its the coolant sensor, because when I floor it its pushing more gas and all the gas gets burned because of the higher rev. Is this true?
Ok, heres the exact problem,
Ok Ive asked about this missing problem when I first start up the car. well Ive tried just about everything, I cleaned the MAF, Cleaned the IAC, Reset the computer, Checked spark plugs, and wires, and even the Timing, all that stuff is good. Here is exactly what the problem is. When ever I first start the car weather its warm or cold outside. Its idles right and normal where it should, but when I start driving it will start to miss from 600 to about 1500rpm then after 1500rpm it sounds normal and runs ok still not full power but way better not missing. almost like it goes away. but after about 5 minutes of driving it complete goes away or until its fully warmed up.It does this pretty much every time I start the car, also it has something to do with the Idle as well, normally when this problem occurs the Idle will drop down to 600rpm or so and thats how you know when it will start missing. For some reason why does the idle drop down? Can anyone help me with this problem, I would rather not take it to a mechanic If i can help it.
i got the same problem too...and to think of it i had some funky code related to the ect...can't remember right now
it will idle ok,but when start to leave the house the check engine light will flash then never come back on
few minutes later stutter...10 min into driving quit all together?????? i'll let you what i find out...
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
