guage wiring
guage wiring
What did you guys use for your power source and your ground on you guages. I have a elec.water temp and a volts guage. I cant figure out what to do cuz i need 4 grounds and 4 power. Pics would be awsome to.
RE: guage wiring
a ground is a ground!! I bridged all my gauge grounds into one common ground on the pilliar post and it works well and is hidden....scuff the paint up to get a good connection
RE: guage wiring
find a switch source from the fuse box with a tester and like all the powers and grounds to gather to come up with 2 wires one ground and one power than ground out anywhere and get ur power from the fuse box, and if ur that bad just open ur fuse box and get ur power from ur sterio. and than if ur even that bad take the ground and power from the back of ur deck if you have an aftermarket. hope this helps
RE: guage wiring
i have no idea on what your talking about take it from my fuse box??? wear am i supose to stick the wire. i think im going to ground them all to the body somewhere, then take the power for the lites from the clockwiring and the power for the guages from the remote wire.
