ACT
Old Dec 1, 2007 | 10:23 PM
nacanitihs's Avatar
nacanitihs
Default ACT
ok my car idles high when its warm at about 1200-1300 rpm when its cold it idles at about 900. its not an intake leak cuz ive sprayed the intake w/ carb cleaner several times and notihng happened. could my ACT or coolant temp sensor be bad? or do you guys have any other opinions?
also would a bad ACT or coolant temp sensor hurt my gas mileage? i used to get 20mpg and now i get 15/16mpg thanx everyone
Old Dec 1, 2007 | 10:28 PM
mnile9127's Avatar
mnile9127
Default RE: ACT
sounds like the coolant temp sensor. it will make the car run rich.
Old Dec 2, 2007 | 02:01 AM
nacanitihs's Avatar
nacanitihs
Default RE: ACT
really? cool. i guess ill just replace them both then
Old Dec 2, 2007 | 07:43 AM
Joel5.0's Avatar
Joel5.0
Default RE: ACT
Ask the brain making the decisions for A/F and spark advance, check the system for ACT or ECT failure codes. If the system sees they are within specifications, why fix/replace something that is not broken........ DIY KOEO/KOER/Cylinder Balance Self-Test
Old Dec 2, 2007 | 07:59 PM
nacanitihs's Avatar
nacanitihs
Default RE: ACT
to test thoes i need to do a KOER test correct? would i have a CEL if they were bad? cuz the CEL is not on.
Old Dec 2, 2007 | 08:07 PM
Joel5.0's Avatar
Joel5.0
Default RE: ACT
ORIGINAL: nacanitihs
The system is in a continuous self-test mode always, in the event of a failure, it will be logged in memory (2nd. set of codes in a KOEO). A KOER will test the system real-time during its execution only.
carid
Jul 8, 2016 09:55 AM
svfetter
Oct 5, 2015 11:39 AM
wraith777
Sep 28, 2015 10:49 AM
96stang3.8
Sep 10, 2015 06:42 AM
zanemoseley
Sep 6, 2015 12:58 PM
