help..fan hiting shroud on 91 mustang gt
Old 09-02-2007, 07:06 PM
91GTSTANGKID
91GTSTANGKID's Avatar
Default help..fan hiting shroud on 91 mustang gt
K...So i have a 91 gt mustang and i just replaced the fan but when i tighten the shroud up the fan hits it.....i dont know why but its a doorman aftermarket fan
91GTSTANGKID is offline
Old 09-02-2007, 07:08 PM
mattdel
mattdel's Avatar
Default RE: help..fan hiting shroud on 91 mustang gt
so....
was the new fan bigger?
i mean come on...
mattdel is offline
WhiteWindsor
WhiteWindsor's Avatar
Your motor mounts are probably shot.
WhiteWindsor is offline
Old 09-02-2007, 07:11 PM
ponyboy302
ponyboy302's Avatar
i had that problem when i changed my water pump .. i dont know if my shroud holes were just worn out lol but the shroud was slightly adjustable as far as moving it up and down .. when i saw it was hitting the fan i just loosened up the screws lifted it up and tightened the screws .. problem was fixed
ponyboy302 is offline
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
reposition fan shroud until it fits[&:]
mjr46 is offline
Old 09-02-2007, 07:16 PM
LTnone
LTnone's Avatar
The shroud holes are oblong, so you can adjust the thing. Move it up a bit
LTnone is offline
Old 09-02-2007, 10:44 PM
stang8689
stang8689's Avatar
You have tomodify it, you need to trim so plastic off, i had to with my flex a lite
stang8689 is offline
Old 09-02-2007, 11:07 PM
r.barn
r.barn's Avatar
ORIGINAL: FASTBLACK
Yepper
r.barn is offline
Old 09-02-2007, 11:53 PM
ncplaya88
ncplaya88's Avatar
engine mounts
ncplaya88 is offline
Old 09-03-2007, 12:12 AM
cleanfitty
cleanfitty's Avatar
ORIGINAL: ncplaya88
engine mounts
It just happened when he replaced the fan... So i strongly doubt the motor mounts went bad at the same time. Either the fan is shaped different, or the shroud ain't on right.
Make sure you position the 2 clips on the bottom of the rad to line up with the 2 notches on the shroud.
cleanfitty is offline
Quick Reply: help..fan hiting shroud on 91 mustang gt
