HEADS????
RE: HEADS????
well trick flow doesnt come in 1.9 intake valves so those are out, only thing left is holley which are ok but too expensive for what they are, eddys are good and cheap, and obviously afr is the way to go if your willing to spend the extra hundreds.
RE: HEADS????
ORIGINAL: capri_83
that is whatIheard also...... I will price a set......thanks.
RE: HEADS????
ORIGINAL: Mustangkiler
RE: HEADS????
ok well your probably right, just pointing out they dont come with 1.9 valves and if your trying to build a motor more for down low torque and not high horsepower then you would want to run the smaller 1.9 valve, i figured thats waht he was going for.
RE: HEADS????
only that if your using stock bottom end the pistons need to be notched, if you look up at the beginning of the 5.0 page where all the threads and stickies and all that are, there should still be one up there about patriot heads and what they gained on a carbed 5.0 from texas hot rods.
RE: HEADS????
https://mustangforums.com/m_4282512/tm.htm
There's some usefull info for you that may help you decide which way to go.
