minor problem
Old Dec 5, 2007 | 12:16 PM
xpvuey239w's Avatar
xpvuey239w
Default minor problem
I have recently got my 95 gt 5.0 aode back on the road. it was off for about 6 months due to transmission rebuild. i didnt have the 1800 bux to do it right away. now when i drive and am over like 30 mph and floor it theres only a little delay between pshing the accelorater down and going. when im stopped at a light and i floor it it seem to be a delay i jam it and it doesnt accelorate hard or anything. and the other problem is when i hit my breaks sometimes or accelorate to hard mhy E brake light comes on for no reason then goes off like 3-4 mins later. if anyone has any ideas i would greatly appreciate them . thankyou
Old Dec 5, 2007 | 05:52 PM
xpvuey239w's Avatar
xpvuey239w
Default RE: minor problem
ne 1?
Old Dec 5, 2007 | 08:01 PM
toofst4u666's Avatar
toofst4u666
Mayb your Throttle Position Sensor? i was having a similar problem on my 88 and that resolved it as for the E brake light i cant help you there
Old Dec 5, 2007 | 08:36 PM
xpvuey239w's Avatar
xpvuey239w
thanks. was that an expensive fix?
Old Dec 5, 2007 | 08:44 PM
mudvayne1's Avatar
mudvayne1
Check your ground on your e-brake. Just take the center console storage thing out. Mine would do that every now and then, and when I changed my console out I found that the wire wasn't screwed down tight enough.
Old Dec 5, 2007 | 09:22 PM
xpvuey239w's Avatar
xpvuey239w
ORIGINAL: mudvayne1
thanks alot ill check in the morning and post tomorow. thanks for your help
Old Dec 5, 2007 | 09:27 PM
bikeboy587's Avatar
bikeboy587
check ur brake fluid. the light can also mean low fluid
Old Dec 6, 2007 | 02:24 PM
toofst4u666
my throttle position sensor was like 30 bucks at autozone and its takes like 5 minutes to install jus disconect ur battery wait like 10 15 minutes and its jus two screws and a clip its right on top of ur throttle body
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
stangin1996gt
Sep 21, 2015 11:01 AM
trashxtrash
Sep 20, 2015 10:49 PM
LivingInThePast
Sep 16, 2015 12:20 PM
