Charging system fixed
Old Dec 7, 2007 | 07:21 PM
tmajikman's Avatar
tmajikman
Default Charging system fixed
I just wanted to let other fox owners know that I have actually found a way to help with the fox charging system, I had ordered a 3G alt, new 4 guage power and ground wire and still could not get my car to charge at idle. I just ordered an overdrive pulley for the alternator and I actually am able to charge at idle with the heat on full blast, lights on and electric fan running. The car was only charging at 11.4 volts and now the car charges at 12.7 volts at idle with all the accessories listed above.
Old Dec 7, 2007 | 07:34 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: Charging system fixed
hmmm....I would expect it to be at least 13.5 and or above... cause nominal batt voltage is 12.6...how are you reading the voltage??? with what type of meter???
Old Dec 7, 2007 | 07:38 PM
86 5.0L's Avatar
86 5.0L
[&:] I think you have a deeper problem if you need a 3g alternator + a OVERdrive pully
tmajikman's Avatar
tmajikman
ORIGINAL: mjr46
Without the heat going and everthing else I do get 13.5, without any accessories I charge at 14.3 at idle, I did use a digital multi meter hooked up the the battery with the car running to come up with my readings. Like you have told me before I could have a bad alt, but at least the system does not discharge at idle.
Old Dec 7, 2007 | 07:40 PM
dillon1340's Avatar
dillon1340
i've never had a charging problem. 14 volts at idle. all i did was put a summit 100 amp alternator on. before that it was ok too though.
Old Dec 7, 2007 | 08:23 PM
tmajikman's Avatar
tmajikman
I have changed everything on the car as far as the charging goes, I do get 14.3 at idle with no accessories on.
Old Dec 10, 2007 | 10:49 AM
Jfsram's Avatar
Jfsram
This is a serious question. Why is charging at idle so important?
I've been discharging at idle since I bought my car. It's very low during idle and accessories on, especially fans and AC at the same time.
My battery has never went dead and even after getting caught in traffic, forcing me to discharge for a good length of time, I can easily start the car afterwards.
Old Dec 10, 2007 | 10:53 AM
farfromu's Avatar
farfromu
alternator runs car battery just another load. so as long as u go above idle no prob.
Old Dec 10, 2007 | 12:28 PM
86 5.0L's Avatar
86 5.0L
ORIGINAL: Jfsram
becuase if it doesnt charge at idle theres a problem with something, the alternator, the grounding, plus who whats a dead battery after sitting in stop-n-go traffic [:-]
Old Dec 10, 2007 | 01:30 PM
92cobra's Avatar
92cobra
ya my battery died on me last night, so ive decided to get the 3g alt and do the swap for an xmas gift to myself. When i have to have the rear defrost on, heat on full blast, brights on, radio on, and at times possibly the electric fan, i guess it drains the battery lol.
