ring ?
Old Dec 8, 2007 | 04:26 PM
F5GTS331's Avatar
F5GTS331
Default ring ?
is there any other specific way to install rings other than staggered?
Old Dec 8, 2007 | 04:50 PM
67mustang302's Avatar
67mustang302
Default RE: ring ?
They should come with instructions that tell you how the particular rings should be installed.
Old Dec 8, 2007 | 04:55 PM
my77stang's Avatar
my77stang
Default RE: ring ?
why would you want to install them any other way? i mean, i have seen people install them in 1/3 increments, and other people install the top two rings opposite from each other but either way is staggered. i use the 1/3 method myself
Old Dec 8, 2007 | 05:13 PM
F5GTS331's Avatar
F5GTS331
Default RE: ring ?
k well some guy told me there was a certain way you have to start the first on in which direction you install the piston and i had never heard that so i was just checkin to make sure he was or wasn't full of b/s that's all this topic is about
Old Dec 8, 2007 | 05:40 PM
dimebag's Avatar
dimebag
Default RE: ring ?
no there is... well some ppl do it... i cant remember that exactly tho
i know what i do is...
three oil rings-i stager.... and the two top rings i do 180 from each other
Old Dec 8, 2007 | 06:19 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
Default RE: ring ?
ORIGINAL: F5GTS331
you stagger them like everyone says and there are usually little dots on the rings right where they butt together..the dots on the top ring and lower ring face up upon installation
Old Dec 8, 2007 | 09:32 PM
my77stang's Avatar
my77stang
Default RE: ring ?
who needs rings anyways? no rings = more lubrication right?
Old Dec 8, 2007 | 09:51 PM
8banger's Avatar
8banger
Default RE: ring ?
Bottom of page 2 "Ring Orientation Diagram"
http://www.jepistons.com/dept/tech/d...instrc4032.pdf
Same for most aftermarket pistons that I've used..or follow the instructions given with your set..
Old Dec 9, 2007 | 09:16 AM
F5GTS331's Avatar
F5GTS331
Default RE: ring ?
oh well i guess i'll just stagger them like i've always done
SteelerNation82
Mar 9, 2025 11:40 AM
Dathan
Oct 5, 2015 05:52 AM
DJ Piner
Sep 30, 2015 03:03 PM
rocket22
Aug 28, 2015 07:08 PM
jesse1125
AmericanMuscle.com
Aug 26, 2015 02:34 PM
